How do I see the list of geolocations?
It is possible to check all work and employee geolocation history. The geolocation list allows the maintenance manager to check the location history.
To see the list, on the menu select the option "Workshops and Employees | Explore | Geolocations".
The list follows these criteria:
- It is only available for the administrator role.
- By default, only the locations on the current quarter are presented.
- You can filter by employee, latitude and longitude
- From the list it is possible to access the employee view screen.
How to create mobile reports?
To create a mobile report, select the Definitions | Printing | Mobile Reports; The list of mobile reports is presented; Press the "Create" button. The report creation screen is presented; When creating the mobile report must consider the following ...
How to see the list of failures?
From the Work Order it is possible to record asset failures. The failure list allows the maintenance manager to see asset failures by work order. To see the menu list select the option "Work | Explore | Failures". The failure list follows these ...
How can I see the list of parent device changes?
With the profile of Administrator, you can see the list of parent device changes of the assets. This list is available at Assets | Explore | Parent Device Changes with the following specifics: Only available for the Administrator. From the list, you ...
How do I view the geolocation history?
This list displays the history of geolocations synchronized by the application, sorted by user. The user login details, sync date and respective latitude and longitude are displayed, and a connection to Google Maps is created automatically to view ...
How to see the list of inactivations?
The inactivations list allows the administrator to view the inactivations history. To view the list, select the option "Assets | Explore | Inactivations". The inactivations list follows these criteria: It is only available for the administrator ...
