How to see the list "My Requisitions"?
The technician has a list where it is possible to view all his requisitions.
To view the list, on the menu select the option Work | My Requisitions.
The list has the following criteria:
  1. It is only available for the technician role.
  2. The list is ordered in decreasing order of requisition date.
  3. From the list it is possible to access the requisition screen.
  4. It is possible to search the list using the search box and by selecting the field to be searched on the 3 dots.
  5. You can apply the following filters:
    1. Date: It is possible to search all the requisitions created on that time period;
    2. Requisition Type: It is possible to search by requisition type;
    3. States: It is possible to search by requisition state;
    • How to create requisitions using a work order?
      It is possible to create and manage requisitions through a work order. The work order must be in a state that allows creation requisitions. To create a requisition from a work order you must: Access the work order list Select the work order for which ...
    • How do I create requisitions?
      Using the requisitions, the employees in an organization can request parts to maintenance. To create a requisition, follow these steps: Go to Requisitions | Requisitions; Click on Create; Fill in the necessary fields. Click on Save and New. ...
    • How to view the requisitions workflow?
      You can change the flow of states for requests to ensure that they match the organization's way of working. To create or change the settings for a status, follow these steps: Access Settings | Requisitions | Workflow; Click on Create or select an ...
    • How to see the list of failures?
      From the Work Order it is possible to record asset failures. The failure list allows the maintenance manager to see asset failures by work order. To see the menu list select the option "Work | Explore | Failures". The failure list follows these ...
    • How can I see the list of parent device changes?
      With the profile of Administrator, you can see the list of parent device changes of the assets. This list is available at Assets | Explore | Parent Device Changes with the following specifics: Only available for the Administrator. From the list, you ...
