How to report consumptions using a requisition associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders", select the WO that you wish to report the cost.
  1. On the work order file, on the link "Operations" select the option "Consumptions";
  2. The consumption records list associated to the WO is presented;
  3. Press the option "Copy from";
  4. On the Requisitions by requested part list, select the parts to record consumption;
    1. Select "Create Consumption";
    2. When filling in the consumption record, you must consider:
    3. By default, the field equipment, tool or location is filled in with the work order asset;
    4. If the work order is for a route, select the asset category and fill in the corresponding asset;
    5. It is only possible to record consumptions, if the work order state allows to record costs
    6. It is only possible to select warehouses for the company recorded on the Requisition.
    7. It is only possible to record a quantity equal or inferior to the one selected on the Requisition.
    8. The workshop manager the work order belongs to can create, edit and delete records for the technician.
Validate the data filled in automatically using the Requisition.
    • How to report consumptions associated with the work order?
      When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders", select the WO that ...
      When a work order is in a state that allows to record costs, it is possible to record  material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
    • How to create requisitions using a work order?
      It is possible to create and manage requisitions through a work order. The work order must be in a state that allows creation requisitions. To create a requisition from a work order you must: Access the work order list Select the work order for which ...
    • How to consume spare parts on the work order?
      On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
    • How to create requisitions?
      Using the requisitions, the employees in an organization can request parts to maintenance. These allow the maintenance teams to respond to different requests by creating corrective work orders. ​  To create a new Requisition, select the ...
