How to report consumptions associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO that you wish to report the cost.
- On the work order file, on the "Operations" link select the option "Consumptions"
- The consumption record list associated to the WO is presented
- Select the option "Create"
To fill in the consumption report, you must consider:
- By default, the field equipment, tool or location is filled in with the Work Order asset;
- If the Work Order is for a Route, select the asset type and fill in the corresponding asset;
- The consumption can be reported to the work order, the maintenance plan to the maintenance plan task or to additional tasks
- Report to the maintenance plan:
- select the maintenance plan you wish to report.
- You can only report to the maintenance plans associated to the work order.
- Report to the maintenance plan task
- Select the maintenance plan.
- You can only report the tasks associated to that maintenance plan
- Report to additional tasks
- You can only report to the tasks associated to the work order.
- The record date cannot be inferior to the work order creation date.
- If the Work Order is for a Route, one of the fields equipment, tool or location must be filled in.
- It is only possible to record consumptions, if the Work Order state allows to record costs
- You can select company warehouses you are reporting consumptions to.
i. The workshop manager the work order
belongs to can create, edit and cancel records for the technician.
Fill in the data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
How do I report consumptions using a requisition associated with the work order?
When a work order (WO) is in a state that allows to record costs, it is possible to record material consumption. However, before registering, you should note that: it is only possible to register consumptions if the WO status allows cost ...
How do I report consumptions associated with the work order?
When a WO is in a state that allows to record costs, it is possible to record material consumption. However, you should consider that: you can only associate the labor with the authenticated user. you can only select warehouses from the company to ...
How to report the task verification associated with the work order?
When a work order is in a state that allows to record costs, it is possible to perform the task verification. To check the tasks, you must access the work order file "Work | Work Orders", select the work order that you wish to check the task of. On ...
How to report consumptions at the average cost?
To record material consumptions at the average cost, you must create a Work Order type "Settings | Work | Work Order Types" and select the "Use Average Cost Price" option available on the "Costs" tab. When a work order is in a state that allows costs ...
