How to record spare parts in an equipment or tool?
In
an equipment or tool, you can associate spare parts.
To
associate them, follow these steps:
- Access
the Menu in the option "Assets" - "Equipment"
/ "Tools"
- Edit or
create "Equipment" / "Tools"
- On the Spare
Parts tab, you can add a Part and the corresponding quantity, you
can also add a remark
If you change the base unit of the spare part for an equipment or
tool, that change will only be reflected on new records or on existing records,
if you are changing those
How to use spare parts?
In an equipment, tool or location, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Location" / "Equipment" / "Tools" Edit or create "Location" / "Equipment" / "Tools" On the Spare Parts ...
How to consume spare parts on the work order?
On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
How to batch delete spare parts?
To delete spare parts select the option Settings | General | File Import: The import screen is displayed; Select the option Delete Location Spare Parts (if you wish to delete location's spare parts) or Delete Equipment or Tool Spare Parts (if you ...
How to import spare parts?
The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
How to view spare parts by asset?
The spare parts list allows to have an overview of the pieces used, where they are used and the quantities needed. To view the list, on the menu select the option Assets | Explore | Spare Parts or search Spare Parts. The spare parts list has the ...
