When a work order is in a state that allows to record costs, it is possible to record labor costs. To record the labor costs, you must access the work order file that you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost.
- On the work order file, on the "Operations" link select the option "Labor"
- The labor records list is presented
- Press the option "Create"
To fill in the labor record, you must consider:
- By default, the field equipment, tool or location is filled in with the Work Order asset;
- If the Work Order is for a Route, select the asset type and fill in the corresponding asset;
- The labor can be reported to the work order, the maintenance plan to the maintenance plan task or to additional tasks
- Report to the maintenance plan:
- select the maintenance plan you wish to report.
- You can only report labor to the maintenance plans associated to the work order.
- Report labor to the work order task
- Select the maintenance plan.
- You can only report the tasks associated to that maintenance plan.
- Report labor to additional tasks
- You can only report labor to the tasks associated to the work order.
- The labor record date cannot be inferior to the work order creation date.
- If the Work Order is for a Route, one of the fields equipment, tool or location must be filled in.
- You can only associate the labor to the authenticated user.
- It is only possible to record labor, if the Work Order state allows cost record
- The workshop manager the
work order belongs to can create, edit and cancel records for the technician.
Fill in the data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
How to report the task verification associated with the work order?
When a work order is in a state that allows to record costs, it is possible to perform the task verification. To check the tasks, you must access the work order file "Work | Work Orders", select the work order that you wish to check the task of. On ...
How do I consult the Labor List?
Through the Labor list, the maintenance manager can verify all the associated labor logs. To consult the Labor list, simply go to Work | Explore Costs | Labor or search for Labor. This list is only available for the Administrator and Work Manager ...
How to report consumptions associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
How to report misc costs associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record misc costs. To record misc costs you must access the work order file you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost. ...
How to report downtime associated with the work order?
An asset, location, equipment or tool can be unavailable for a period of time. To report down time associated to a work order, you must execute the following steps: Access the option "Work | Work Orders"; Edit the desired Work Order using the ...
