How to record a stock parts entry?
The stock parts entry is always associated to a warehouse, it is
not possible in a single stock entry to place several warehouses. To enter a
part stock, you must access the warehouse tab "Inventory Parts |
Warehouses", select the warehouse you wish to enter stock on.
On
the warehouse tab, in the "Operations" link, select the
"Part Entries" option;
The
list of parts entries associated with the selected warehouse appears.
Select
the option "Create".
Enter the data. The information to be filled in is organized in
tabs. You can see the required fields using the orange margin or from the list
on the right lower corner, next to the Reset button;
It
is not possible to delete part entries, to remove parts from stock you must
issue a parts issue.
It
is not possible to add part entries in externally managed warehouses.
How to report/delete a stock parts issue?
The stock parts issue is always associated to a warehouse, it is not possible in a single part issue to place several warehouses. To issue a part, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish to ...
How to view the current stock for the warehouse parts?
The Parts / Warehouse list allows the maintenance manager to view the existent parts stock in each warehouse. To view the list, select the option "Parts and Inventory | Explore | Parts Stock" or search "Parts Stock". The Parts Stock list has the ...
How do I consult the parts/warehouses list?
Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
How do I see the list of parts entries?
The parts entry list allows the administrator to view the parts entry. To view the list, select the option "Parts and Inventory | Explore | Parts Entry". The parts entry list follows these criteria: It is only available for the administrator role. ...
How to record spare parts in an equipment or tool?
In an equipment or tool, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Equipment" / "Tools" Edit or create "Equipment" / "Tools" On the Spare Parts tab, you can add a Part and the ...
