How to print the part label?
To print the part label, view the report on the list. On the context menu (button "..."), you can find these options:
- Print tag - prints the current report label;
- Print all tags - prints all reports with the label defined
- Tag Templates - opens the label configurations list
The field coded on the label is "Tag" and it is printed using the label configuration by default. The option "Print All Tags" prints alphabetically and at the most, 10000 reports
To print the part label, view the report on the list. On the context menu (button "..."), you can find these options: Print tag - prints the current report label; Print all tags - prints all reports with the label defined Tag Templates - opens the ...
How to print the asset(equipment, tool or location) label?
To print the asset label, view the report on the list. On the context menu (button "..."), you can find these options: Print tag - prints the current report label; Print all tags - prints all reports with the label defined Tag Templates - opens the ...
How to print a Work Order task verification report?
To print a work order task verification report, you need to follow these steps: Go to Work | Work Orders; Select a work order record; In the bottom left-hand corner, click on the three dots to access the Print Verification Report option. This report ...
How do I manage batch work orders?
Work Order (WO) management was designed to increase the maintenance manager productivity. Thus, with this feature, the manager is now able to: change the state of several WOs simultaneously; print several WOs simultaneously; To manage WOs in batch, ...
How to report/delete a stock parts issue?
The stock parts issue is always associated to a warehouse, it is not possible in a single part issue to place several warehouses. To issue a part, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish to ...
