How to print the asset(equipment, tool or location) label?
To print the asset label, view the report on the list. On the
context menu (button "..."), you can find these options:
- Print tag - prints the current report label;
- Print
all tags - prints all reports with the label defined
- Tag
Templates - opens the label configurations list
The field coded
on the label is "Tag" and it is printed using the label configuration
by default. The option "Print All Tags" prints alphabetically and at
the most, 10000 reports
Tag templates with Code 39, Code 93, EAN 13 and Interleaved2of5 encoding do not support multi-line printing. In these templates the "Keyword" will not be included.
How do I report down time for an asset (equipment or tool) or location?
An asset can be unavailable during a period of time. To report downtimes, select the option "Assets | Equipments or Assets | Tools" or "Assets | Locations". The list of equipments, tools or locations is presented; Select the equipment, tool or ...
How do I change an asset's location?
To change the location of an asset in batch, select the option in Assets | Equipment or Assets | Tool: The equipment or tools list is presented; Select from the list the equipment or tool that you wish to change the location; Press the ...
How to create equipment from Generated Equipment?
To create equipment or tools from the Generated Equipment list, you need to save the Equipment Reception document. The lines in which the Status column shows Accepted will originate an Equipment or Tool, as indicated in the Is Tool column. Once a ...
How to print the part label?
To print the part label, view the report on the list. On the context menu (button "..."), you can find these options: Print tag - prints the current report label; Print all tags - prints all reports with the label defined Tag Templates - opens the ...
