The
parts can be inserted from individual records or in
batches by importing .csv files..
To batch
load parts, follow these steps:
- Select the Settings| General | File Imports option or access the parts list (Parts and
Inventory | Parts) and select the Import Parts option;
- The import
screen will be displayed;
- Select the Import Parts option;
- Download
the template file at the top of the screen and fill it in according to the
following rules:
- The PartKey, Description, PartType, BaseUnit and Warehouse fields are mandatory.
- If the PartKey field is not filled in, the line will be ignored.
- If the Family and FamilyDescription fields are set, the family will be created or
updated. The same applies to the Warehouse, Brand, BrandModel and PartSubType fields, with the corresponding references:
- Warehouse and WarehouseDescription;
- Brand and BrandDescription;
- BrandModel and BrandModelDescription;
- PartSubType and PartSubTypeDescription;
- If the Family field is filled in, you must also fill in the FamilyDescription field;
- If the Warehouse field is filled in, you must also fill in the WarehouseDescription field;
- If the Brand field is filled in, you must also fill in the BrandDescription field;
- If the BrandModel field is filled in, you must also fill in the BrandModelDescription field;
- If the PartSubType field is filled in, you must also fill in the PartSubTypeDescription field;
- To create a
part with inventory, the Warehouse field must be filled in.
- When the
import is complete, the import date will be displayed. Messages with the import
details will be displayed if there are any errors or warnings. If the import
occurs without errors/warnings, no additional information will be displayed. If
there are errors/warnings, you can check by clicking on the number of messages.
- The file
links must be added in the Attachment1, Attachment2...Attachment10 columns.
Each record has a maximum limit of 10 attachments. If this value is exceeded,
the attachments will not be added. For example, if a piece already has four
attachments, only six more attachments will be added.
- If you redo
the import, the parts attachments will be added again, regardless of whether
they have already been added in another import.
- Attachments
must be stored on Dropbox, GoogleDrive or another storage service that provides
a direct download link.
- The image
of the part must be stored on Dropbox, GoogleDrive or another storage service
that provides a direct download link..
- The value
format of the MinStock, MaxStock and UnitCost fields must be in the format of
the selected culture.
When
filling in the file, the following aspects must be taken into account:
- The file
must always be a CSV file and the separator icon must be the ; (semicolon);
- Each file
should not contain more than 2,000 records or 4 Mb.
- Each file
must not contain more than 7,500 attachments or 4 Mb.
- The average
upload time for each attachment or image is around 1.3 seconds. However, this
may vary depending on the size of the file, internet speed, storage service and
other factors external to Valuekeep.
You must
not remove or add columns to the downloaded template file.
