How to define the Scheduling Labor Costs?
    • How do I consult the Labor List?
      Through the Labor list, the maintenance manager can verify all the associated labor logs. To consult the Labor list, simply go to Work | Explore Costs | Labor or search for Labor. This list is only available for the Administrator and Work Manager ...
    • How do I consult the Miscellaneous Costs list?
      The maintenance manager can check all the miscellaneous cost records associated with a work order. You can access this list under Work | Explore Costs | Miscellaneous Costs or by searching for Miscellaneous Costs in the search available in the ...
    • How can I see the Costs dashboard?
      The dashboard Costs shows metrics and indicators related to the recording of costs in work orders. To access this dashboard, click on the icon Applications in the top left corner of the header, and then on the option Analytics. A tab will open with ...
    • How to define the execution of maintenance plans?
      Each maintenance plan of the preventive maintenance has a scheduling configuration. The scheduling can be defined using: Recurrence; Meter; Recurrence and Meter Recurrence The scheduling by each plan's recurrence supports three configuration types: ...
    • How can I see the list of Total Costs?
      The maintenance manager can check all the cost records associated with a work order. You can access this list of costs at Work | Explore Costs | Total Costs or by searching for Total Costs inthe search bar in the header. The list of total costs has ...
