How to define a maintenance plan tolerance in a preventive maintenance?
When creating a preventive maintenance, on the tab "Planned Work", you can add a Maintenance Plan and in that plan, you can add the following tolerances:
  1. Advance Tolerance
  2. Delay Tolerance
 The tolerance considers the following logic:
  1. Advance Tolerance: if the difference between the event date and the event expected date is higher than the advance tolerance, the event will be adjusted to the new,
  2. Delay Tolerance: if the difference between the event expected date and the event date is higher than the delay tolerance, the event will be adjusted to the new data.
    • How to define a maintenance plan tolerance in a preventive maintenance?
      When creating a preventive maintenance, on the tab "Planned Work", you can add a Maintenance Plan and in that plan, you can add the following tolerances: AdvanceTolerance DelayTolerance The tolerance considers the following logic: AdvanceTolerance: ...
    • How to plan the preventive maintenance for several years?
      The events are not all generated when the preventive maintenance is approved. The events are rescheduled daily according to a set of rules. The following rules: Events based on the recurrence:  If the preventive has a daily plan, a maximum of 2 years ...
    • How to define the execution of maintenance plans?
      Each maintenance plan of the preventive maintenance has a scheduling configuration. The scheduling can be defined using: Recurrence; Meter; Recurrence and Meter Recurrence The scheduling by each plan's recurrence supports three configuration types: ...
    • How to set the preventive maintenance plan replacement?
      On the maintenance plans of a preventive maintenance, it is possible to select the replacement criteria. The replacement criteria can be the following: None main (Multiplier) Replacement The plan replacement rules are the following: All maintenance ...
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
