How to define a maintenance plan tolerance in a preventive maintenance?
When creating a preventive maintenance, on the tab "Planned Work", you can add a Maintenance Plan and in that plan, you can add the following tolerances:
- AdvanceTolerance
- DelayTolerance
The tolerance considers the following logic:
- AdvanceTolerance: if the difference between the event date and the event expected date is higher than the advance tolerance, the event will be adjusted to the newdata.
- DelayTolerance: if the difference between the event expected date and the event date is higher than the delay tolerance, the event will be adjusted to the new data.
How to plan the preventive maintenance for several years?
The events are not all generated when the preventive maintenance is approved. The events are rescheduled daily according to a set of rules. The following rules: Events based on the recurrence: If the preventive has a daily plan, a maximum of 2 years ...
How to define the execution of maintenance plans?
Each maintenance plan of the preventive maintenance has a scheduling configuration. The scheduling can be defined using: Recurrence; Meter; Recurrence and Meter Recurrence The scheduling by each plan's recurrence supports three configuration types: ...
How to set the preventive maintenance plan replacement?
On the maintenance plans of a preventive maintenance, it is possible to select the replacement criteria. The replacement criteria can be the following: None main (Multiplier) Replacement The plan replacement rules are the following: All maintenance ...
How to create a preventive maintenance?
Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
When creating a preventive maintenance, on the tab "Planned Work", you can add a Maintenance Plan and in that plan, you can add the following tolerances: Advance Tolerance Delay Tolerance The tolerance considers the following logic: Advance ...
