In Valuekeep, there are "POST" requests, which come
from keys, as shown below:
The method used to create a follow-up report in a work order is:
POST {{url}}/api/{{tenant}}/{{organization}}//maintenance/workOrders/{Company}}/{WorkOrderKey}}/WorkOrderNotes
To implement a pipeline with the structure specified above, you
must use:
i.Prefix: "@from_";
ii.Tag: "ToEntityKeys";
iii.Number: number of the key you wish to
place on the URL, otherwise, the "default = 1" is used;
iv.Suffix: "@" ;
1. ...
2. ToApiPath
= Maintenance/WorkOrders;
3. ToApiPathPost
= Maintenance/WorkOrders/999/@from_toentitykeys1@/workordernotes;
4. ToCompanyDependent = true;
5. ToExclusiveInsert
= true;
6. ToEntityKeys
= Key,WorkOrderKey;
7. ToCompany
= 999;
8. ...
In the example above one can verify the use of the API by
constructing the following request: https://cloud.valuekeep.com/api/maintenance/workorders/999/{Key}/workordernotes;
{Key}
- The record content that has been mapped in the Mapping file will be presented.
In case you want to use the key 2, you should use the following:
1. ...
2. ToApiPath
3. ToApiPathPost
= Maintenance/WorkOrders/999/@from_toentitykeys2@/workordernotes;
= true;
6. ToEntityKeys
= Key,WorkOrderKey;
7. ToCompany
= 999;
8. ...
constructing the following request: https://cloud.valuekeep.com/api/maintenance/workorders/999/{WorkOrderKey}/workordernotes;
{WorkOrderKey}
presented.
The
keys can also be used simultaneously.
