How to create requisitions using a work order?
It is possible to create and manage requisitions through a work order.
The work order must be in a state that allows creation requisitions.
To create a requisition from a work order you must:
  1. Access the work order list
  2. Select the work order for which you want to create a requisition
  3. Access the "Operations" option and select the Requisitions option
    • How do I create requisitions?
      Using the requisitions, the employees in an organization can request parts to maintenance. To create a requisition, follow these steps: Go to Requisitions | Requisitions; Click on Create; Fill in the necessary fields. Click on Save and New. ...
    • How to consume spare parts on the work order?
      On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
    • How to create a work order type?
      Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
    • How do I create the work order type?
      Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
    • How to report labor associated with the work order?
