How to create requisitions on a work order?
When a work order is in a state that allows to create
requisitions. To create requisitions on the WO, you must access the work
order file it belongs to in "Work | Work Orders" and select
the desired WO.- On the work order file, on the link "Operations"
select the option "Requisition";
- The list of requisitions regarding the WO
will be displayed;
- Select the option "Create".
How to create requisitions using a work order?
It is possible to create and manage requisitions through a work order. The work order must be in a state that allows creation requisitions. To create a requisition from a work order you must: Access the work order list Select the work order for which ...
How to create a work order type?
Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
How to create a related work order?
Frequently, a maintenance technician is performing a work order and detects another problem, so he needs to solve it and log the work done. To log the work done, there are 3 options: Creating a new work order Adding additional tasks to the work order ...
How to create a work order?
How to consume spare parts on the work order?
On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
