How do I create requisitions?
Using the requisitions, the employees in an organization can request parts to maintenance.
 To create a requisition, follow these steps:
  1. Go to Requisitions | Requisitions;
  2. Click on Create;
  3. Fill in the necessary fields.
  4. Click on Save and New.
Subsequently, if the requisition is in the Locked for changes state, you will not be able to change any attribute.
    1. When the Requisition changes to a state in which the Final State option is set up.
    2. When the Requisition changes to any state other than the final state.
You must change the status in the details query interface.
If the warehouse has access restrictions, when adding a part to the requisition only the warehouses without restrictions and those with access are displayed. This behavior only applies to the Technician profile.
    • How do I enter stock from a requisition?
      From the requisition forms, it is possible to enter stock parts. However, this option is only visible on the requisitions tab after the requisition is approved. To enter stock from a requisition, follow these steps: Access the feature Requisitions; ...
    • How to view the requisitions workflow?
      You can change the flow of states for requests to ensure that they match the organization's way of working. To create or change the settings for a status, follow these steps: Access Settings | Requisitions | Workflow; Click on Create or select an ...
    • How to create requisitions using a work order?
      It is possible to create and manage requisitions through a work order. The work order must be in a state that allows creation requisitions. To create a requisition from a work order you must: Access the work order list Select the work order for which ...
    • How to create email templates?
      Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
    • How to create contracts?
      To create a new contract, select the option "Contracts | Contracts": The contract list is presented: Press the "Create" button. When editing the contract, you must consider: The state change must be performed on the detail view interface. If the ...
