How to create custom mobile reports?
If you wish to create a custom mobile report, you must use our base report.
Click the attachment to download the base mobile report.
    • Custom mobile report – Printing
      Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
    • Mobile - How to report consumptions from the requisition?
      Mobile - How to report consumptions from the requisition? To report consumptions from the requisition, follow these steps: Access Menu | Report Work; On the work order list, select the work order you wish to report consumption; On the work order ...
    • Mobile - How to report/change or delete misc costs?
      To report misc costs, you must perform these steps: Access Menu | Report Work; On the work order  select the work order you wish to view/record the misc costs; On the work order options (3 dot icon) click on Misc Costs; A misc costs report list is ...
    • Mobile - How do I print a work order report?
      The technicians can print the work order report with or without the signature when ending or during the execution. To print a work order report, it is necessary to access the detail window of the workorder. The access to this detail is performed ...
    • Mobile - How do I create, edit or delete failures?
      The failures are always associated to work orders. You can access the failure report using the Menu | Report Work On the Work order list, select the work order failure you wish to view to see; On the work order options (3 dots icon) click on Failures ...
