How to create assets?
The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance.
To create an equipment/tool, select the option Assets | Equipment or Assets | Tool:
  1. The list of equipment or tools is presented;
  2. On the list, press the button "create".
There are a few rules to edit assets, among them:
 - It is only possible to edit the service date if there is no failure or down time reports.
Equipment or Tool Characteristics:
  1. In the Characteristics tab, you can assign one or more characteristics. These can be of the following types:
    1. Number;
    2. Text;
    3. Date/Time;
    4. Boolean;
    5. Enum.
  2. When saving the record, the following validations regarding the characteristics are made:
    1. No repeated characteristics can exist
    2. Number type characteristics:  checks if the text inserted on the Value field is a number. The number of decimal places associated to that characteristics unit is also checked, as well as if the tab matches the user language;
    3. Date/time type characteristics:  checks if the text inserted on the Value field is a date and/or a time.
    4. Boolean type characteristics: checks if the text inserted on the Value field is 0 for False and 1 for True;
    5. Enum type characteristics:  checks if the Enum value matches the values for the selected characteristic.
Working time (hours per day): You can only insert values between 0 and 23:59:59.
If the asset was not created as Available, after the Service Date, the asset is placed automatically as available.
To automatically make it available, you must select the option "Settings | Work | Background Services" and activate the Downtime.
When creating a new asset, this is placed as "Available" and the "Service Date" is set as the current day.
    • How do I create assets?
      The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
    • How do I use the Assets Explorer?
      The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
    • How to associate assets to workshops?
      For bigger clients with several workshops, there is frequently the need to specify assets (equipment, tools and locations) that each workshops have access to. Using this feature, the user can specify the assets associated to each workshop. When ...
    • How to create email templates?
      Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
    • How can I create monitorings?
      The monitorings are system entities which allow for monitoring the normal operation of the assets by monitoring a preset value and, depending on its positive or negative variation, trigger corrective maintenance actions. To create a new monitoring, ...
