How to create a template report for work orders?
To create a new template report for work
orders, select the option Settings | Printing | Reports.
Edit the "Work Order"
template and, on the options, click "Copy to New".
To make this the default report, select the
tab "Entity Groups" and click the option "Default".
To use the company logo, select the tab
"Appearance" and click the option "Use Company Logo".
How to create a template report for lists?
To create a new template report for work orders, select the option Settings | Printing | Reports. Edit the "Lists" template and, on the options, click "Copy to New". To make this the default report, select the tab "Entity Groups" and click the option ...
How to report the task verification associated with the work order?
When a work order is in a state that allows to record costs, it is possible to perform the task verification. To check the tasks, you must access the work order file "Work | Work Orders", select the work order that you wish to check the task of. On ...
How to create a work order type?
Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
How to report consumptions associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
