How to create a request type?
After being configured, the request types allow you to classify requests and apply specific behaviors. To create a request type, select the option Settings | Requests | Request Types:
  1. The list of request types is displayed;
  2. Press the "Create" button.
The request types are divided in 2 main sections:
  1. Main settings
  2. Generate WO. Automatically generated when the request is created.
  3. Create without an asset. Allows to create a request without an asset.
  4. Closing by the requester is mandatory. The requester, the person who recorded the request, is required to close it.
  5. By default. Option that allows a default request, that will be suggested when creating the request.
  6. Default values (when the checkmark Generates WO is activated)
    1. The priority level is now mandatory, that will be the Priority level associated to the generated work order.
    2. The workshop is now mandatory, that will be the workshop associated to the generated work order.
    3. Work order type, that will be the work order type associated to the generated work order.* Mandatory when the option Generate WO is active.
    4. Maintenance Plan, that will be the Maintenance Plan associated to the Work Order.
  7. Remarks - Free text, it can be the detailed description of the request type.
It's not possible to create a request type with the option "Generates WO" and "Create without an asset".
    • How to create a request type?
      After being configured, the request types allow you to classify requests and apply specific behaviors. To create a request type, select the option Settings | Requests | Request Types: The list of request types is displayed; Press the "Create" button. ...
    • How to create a contract type?
      To create a new Contract Type, select the option Settings | Contracts | Contract Types: The list Contract Types will be displayed; Press the "Create" button; When creating and editing Contract Types, you must consider: i.The first Contract Type to be ...
    • How to create a work order type?
      Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
    • How to create a work order to a request?
      Through requests, an organization's employees can request maintenance actions on equipment, tools or locations. These maintenance requests, usually referred to as HelpDesk requests, allow the maintenance teams to respond to different requests by ...
    • How to configure the request workflow?
      The state flow for requests can be changed to be in line with the organization's working method. To create or change the new state configurations, you must access Definitions | Requests | Workflow The state list is presented; To create new states, ...
