On the asset file (location, equipment or
tool), you can specify the parts and the corresponding quantities the asset
needs to work correctly. The parts associated to the assets on the section
"spare parts" can be consumed on the work order using the
following options:
Automatic consumption
The automatic consumption of spare parts of
an asset is performed as follows:
On the work order type, on the tab "Costs",
activate the option "Spare Parts Consumption".
When a work order is placed in a state that allows to record
costs for the first time, a part consumption is automatically recorded
with the parts defined on the spare parts section of the asset file.
If there is not enough stock, the consumption is not performed.
The automatic consumption is only performed
when the work order is placed in a state that allows to record costs for the
first time.
Manual consumption
When a work order is in a state that allows
to record costs, it is possible to record material consumptions. To create
material consumption by associating spare parts, you must:
On the work order file, on the link "Operations"
select the option "Consumptions";
The consumption records list associated to the WO is presented;
Press the option "Copy from spare parts".
On the spare parts list, select the parts to record
consumption;
Select "Create Consumption";
When filling in the consumption record, you
must consider:
i.
By default,
the field equipment, tool or location is filled in with the work order asset;
ii.
If the work
order is for a route, select the asset category and fill in the corresponding
asset;
iii.
It is only
possible to record consumptions, if the work order state allows to record costs
iv.
It is only
possible to select warehouses for the company recorded on the Requisition.
v.
It is only
possible to record a quantity equal or inferior to the one selected on the Requisition.
vi.
The
workshop manager the work order belongs to can create, edit and delete records
for the technician.
