How to consult the Request Management list?
The Administrator and the Work Manager have access to a list of requests.
To access the list, select the menu option Work | Request Management.
List criteria:
- Availability for the Administrator and Work Manager;
- The list is sorted in descending order based on the date of the request;
- From the list, it is possible to access the request display screen;
- It is possible to apply the following filters:
- Date: allows you to search for requests created in a certain period of time;
- Status: allows you to search for a request's status;
- Requests type: allows you to search by request type;
- Active: allows you to search for the active status of a request;
- Priority levels: allows you to search based on the priority level of a request.
The Work Manager profile should only be able to view requests that meet the following conditions:
- The request type does not have a Workshop defined by default;
- The request type has a default Workshop in which the user is a manager.
How to view the state transitions of a request?
A request is created in the initial state and until it is finished, it goes through different states. The requester or the maintenance manager has the chance to view all the states the request went through. For the requester to view the request ...
How to create a work order to a request?
Through requests, an organization's employees can request maintenance actions on equipment, tools or locations. These maintenance requests, usually referred to as HelpDesk requests, allow the maintenance teams to respond to different requests by ...
How to change the state transition dates of a request?
The state transition dates can be changed, for that select the option Work | Work | Request Management The request list is presented Select the request you wish to change the state to On the "Operations" link, select the option "Change State ...
How to configure the request workflow?
The state flow for requests can be changed to be in line with the organization's working method. To create or change the new state configurations, you must access Definitions | Requests | Workflow The state list is presented; To create new states, ...
How to create a request type?
After being configured, the request types allow you to classify requests and apply specific behaviors. To create a request type, select the option Settings | Requests | Request Types: The list of request types is displayed; Press the "Create" button. ...
