How to batch delete spare parts?
To delete spare parts select the
option Settings | General | File Import:
The import screen is displayed;
Select the option Delete Location Spare Parts (if you wish to
delete location's spare parts) or Delete Equipment or Tool Spare Parts (if
you wish to delete Equipment and/or Tool spare parts);
Download the template file to be loaded, on the upper part of
the screen and fill in the file;
Later, you must fill in the file according to the rules:
The fields Key, Part, and Company must be defined.
When the import is finished, the import date will be presented
and it might contain messages with import details. If an import occurs
without errors/warnings, no information on the import details will be
presented. If there are errors/warnings on the import, you can see the
errors by clicking on the number of messages.
The file must always be of the CSV type and the
separator character must be ; (semicolon).
How to import spare parts?
The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
How to consume spare parts on the work order?
On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
How to use spare parts?
In an equipment, tool or location, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Location" / "Equipment" / "Tools" Edit or create "Location" / "Equipment" / "Tools" On the Spare Parts ...
How to view spare parts by asset?
The spare parts list allows to have an overview of the pieces used, where they are used and the quantities needed. To view the list, on the menu select the option Assets | Explore | Spare Parts or search Spare Parts. The spare parts list has the ...
How to record spare parts in an equipment or tool?
In an equipment or tool, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Equipment" / "Tools" Edit or create "Equipment" / "Tools" On the Spare Parts tab, you can add a Part and the ...
