How to assign technicians to the work order?
When a work order is in a state that allows it, you can assign technicians.  To assign technicians on the WO, you must access the work order file you wish to assign in "Work | Work Orders" and select the desired WO.
  1. On the work order file, on the link "Operations" select the option " Assignment";
  2. The list of technicians assigned to the WO will be displayed;
  3. Select the option "Create".
There are 4 categories for assigning technicians to the work order:
i.Work order assignment - the technician will have all tasks from all work order plans assigned, as well as all additional tasks.
ii.Work order maintenance plan assignment - the technician will have all tasks from the maintenance plan assigned.
iii.Maintenance plan task assignment - the technician will have the specific task from the specific maintenance plan assigned.
iv.Additional task assignment - the technician will have the specific additional task assigned.
When assigning technicians to work orders, you must consider the following rules:
i.You can only record the assignment if the work order is in the state Allows Assignments;
ii.Only technicians associated to the work order workshop can be assigned;
When the Work Order type has an automatic assignment to the Workshop technicians, it follows this criteria:
i.If the company has no access restrictions, assign to all workshop technicians;
ii.If the company has access restrictions, assign only to workshops technicians with company access;
iii.Employees unmapped for user must always be assigned;
iv.In the automatic assignment, the work order created should only be assigned if that user is a workshop technician.
    • How do I create the work order type?
      Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
    • How to configure the work order workflow?
      The state flow for work orders can be changed to be in line with the organization's working method. To create or change the new state configurations, you must access Definitions | Work | Workflow  The state list is presented; To create new states, ...
    • How do I manage batch work orders?
      Work Order (WO) management was designed to increase the maintenance manager productivity. Thus, with this feature, the manager is now able to: change the state of several WOs simultaneously; print several WOs simultaneously; To manage WOs in batch, ...
    • How to create a work order type?
      Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
    • How to view the employees assigned to the work order?
      For a technician to execute the work orders on Valuekeep Mobile it is necessary that they are assigned to them. The list of assignments allows the maintenance manager to view the work orders assigned, as well as the technician(s) assigned.  To view ...
