On
the Universe line, you can have a subscription with several companies.
How to restrict user access by company?
When more than one company is added to a subscription, you can specify the user that can access each company. The access restriction process is divided in two phases:
How to set up time zone and reporting currency by company?
When adding more companies to a subscription, it is possible to specify the settings for each company.
The dates present when sending notifications will be converted to the chosen time zone. If a time zone is not chosen, the default will be UTC +00:00
How is the data presented on lists when there is more than one company?
The list data is always filtered by the company selected on the company selector. You cannot view the data for all company simultaneous on the same list.
How to select the company we wish to create the logs to?
After selecting the company on the company selector, the Valuekeep CMMS solution is filtered for the selected company. The new logs created are associated to the company selected on the company selector.
Which data depend on the company?
When there is more than one company, there are data common to all companies and data specific for each company.
As of now, Analytics does not present the data by company.
