How to add maintenance plans to the work order?
To add a maintenance plan to a work order, you must access the work order file and open the tab "Maintenance Plans":
- The list of additional maintenance plans associated to the work order is presented
- On the list, press the button "+" to add one or more maintenance plans.
The task associated to the maintenance plan directly associated. To see the task list, press the additional option of the Maintenance Plan row, on the option Tasks.
A work order cannot have repeated maintenance plans
How to create a work order?
How to add more companies to a subscription?
On the Universe line, you can have a subscription with several companies and define a set of information for each company, including users and time zone. Add more companies to a subscription Access Settings | General | Companies; Press the Create ...
How do I manage batch work orders?
Work Order (WO) management was designed to increase the maintenance manager productivity. Thus, with this feature, the manager is now able to: change the state of several WOs simultaneously; print several WOs simultaneously; To manage WOs in batch, ...
How to join plans on the preventive maintenance?
When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
