How to add an attachment with a preventive maintenance?
To add an
attachment to a preventive maintenance, you must follow these steps:
- Edit the
preventive maintenance and click on the option "Attachments" on the
options on the lower left corner of the screen;
- On the
"Manage Attachments" pop-up, it is possible to add a new attachment
by clicking in select or by dragging the file;
- After
clicking "Confirm", the attachment is associated to a preventive
maintenance;
- Clicking
"Save" will finish the process of adding an attachment.
When
generating a Work Order, if there are attachments in the preventive
maintenance, maintenance plan and task, these will be copied to the Work Order.
How does preventive maintenance rescheduling work?
The preventive maintenance events recalculation is a daily process that recalculates all preventive maintenance events. This recalculation can be done automatically or as requested by the user. To automatically make it available, you must select the ...
How to define a maintenance plan tolerance in a preventive maintenance?
When creating a preventive maintenance, on the tab "Planned Work", you can add a Maintenance Plan and in that plan, you can add the following tolerances: AdvanceTolerance DelayTolerance The tolerance considers the following logic: AdvanceTolerance: ...
How to create a preventive maintenance?
Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
How to add more companies to a subscription?
On the Universe line, you can have a subscription with several companies and define a set of information for each company, including users and time zone. Add more companies to a subscription Access Settings | General | Companies; Press the Create ...
How to join plans on the preventive maintenance?
When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
