How to access the Valuekeep Technician CMMS mobile app?
To access the Valuekeep Technician CMMS,
before entering the app, you must accept
the request previously sent.
Roles supported on the Valuekeep Technician
CMMS app:
- Root - Administrator
- Technician - Technician
- WorkManager - Work Manager
How to access the Valuekeep Requester CMMS mobile app?
To access the Valuekeep Requester CMMS, before entering the app, you must accept the request you've been sent. Roles supported on the Valuekeep Requester CMMS app: Root - Administrator Requester - Requester RequestsManager - Requests Manager If you ...
Mobile - How to do Valuekeep CMMS's configuration?
The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu -> Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
Mobile - How to change the user on the Valuekeep CMMS app?
The operating system where Valuekeep CMMS was downloaded can only be shared by more than one user. If several users use the same device to access Valuekeep CMS, every time they need to access Valuekeep CMMS, they will need to change users. To change ...
Mobile – How to set up the Valuekeep CMMS?
i. The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
Mobile – How to set up the Valuekeep Requester CMMS?
The Valuekeep CMMS can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the language selected in ...
