How to access the Valuekeep Requester CMMS mobile app?
To access the Valuekeep Requester CMMS,
before entering the app, you must accept
the request you've been sent.
Roles supported on the Valuekeep Requester
CMMS app:
Root - Administrator
Requester - Requester
RequestsManager - Requests Manager
If you have Technician or Work
Manager as your main role, when entering the app, your role will be changed
to the associated role with less access.
Example 1:
User:
Associated roles:
Administrator
Requester
Technician
Default role:
Technician
When entering the app, the Technician has
no access to the app, so the role will change to Requester.
Example 2:
User:
Associated roles:
Administrator
Requests Manager
Technician
Default role:
Technician
no access to the app, so the role will change to Requests Manager.
Example 3:
User:
Associated roles:
Administrator
Technician
Default role:
Technician
no access to the app, so the role will change to Administrator.
How to access the Valuekeep Technician CMMS mobile app?
To access the Valuekeep Technician CMMS, before entering the app, you must accept the request previously sent. Roles supported on the Valuekeep Technician CMMS app: Root - Administrator Technician - Technician WorkManager - Work Manager
Mobile – How to set up the Valuekeep Requester CMMS?
The Valuekeep CMMS can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the language selected in ...
Mobile - How to do Valuekeep CMMS's configuration?
The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu -> Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
Mobile - How to change the user on the Valuekeep CMMS app?
The operating system where Valuekeep CMMS was downloaded can only be shared by more than one user. If several users use the same device to access Valuekeep CMS, every time they need to access Valuekeep CMMS, they will need to change users. To change ...
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background. To synchronize the data, you must ...
