How do I register a change of Parent Device on the devices?
To register a change of parent device on a device, follow these steps:
- Go to Assets | Devices;
- Select the device for which you want to register the change of Parent Device;
- Click on the button Operations and then, on Change Parent Device;
- The list of changes to the selected device is displayed;
- Click on Create;
- Fill in the necessary fields;
- Click on Save and confirm the message displayed;
After saving, the device's Parent Device will automatically be changed.
If you make a new change of the Parent Device, the end date of the last change record to the Parent Device will be updated. The end date will be filled in with the start date of the new Parent Device.
How can I see the list of parent device changes?
With the profile of Administrator, you can see the list of parent device changes of the assets. This list is available at Assets | Explore | Parent Device Changes with the following specifics: Only available for the Administrator. From the list, you ...
How do I record parent location change on the locations?
To record a parent location change in a location, select the option Assets | Locations. The list of locations is presented Select the location you wish to record the Parent location change to and press the button "View" On the "Operations" link, ...
How do I change an asset's location?
To change the location of an asset in batch, select the option in Assets | Equipment or Assets | Tool: The equipment or tools list is presented; Select from the list the equipment or tool that you wish to change the location; Press the ...
How to change the state transition dates of a request?
The state transition dates can be changed, for that select the option Work | Work | Request Management The request list is presented Select the request you wish to change the state to On the "Operations" link, select the option "Change State ...
How do I change the preventive event date on the event form?
On the preventive maintenance event form, you can postpone or delay the event date according to the following rules: The new event date must not be earlier than the previous event or later than the next one, in order to maintain the order of the ...
