How do I log orders for Routes?
Through the orders, employees of an organization can address intervention requests on route assets for maintenance.
The route can be:
  1. Static: the administrator selects the associated assets with or without a filter by function/family/brand/model;
  2. Dynamic: the administrator does not select assets but defines the function/family/brand/model. He can also define whether to include the elements of sub-entities (roles/families).
To create an order, follow these steps:
  1. Go to Orders | My Orders;
  2. Click on Create;
  3. Enter an order Description;
  4. In the Active section, in the Type field, select the Route option;
  5. In the Route field, select the desired Route. If it doesn't exist, you can create it;
  6. Fill in the remaining fields;
  7. Click on Save and New.
After generating the order, the assets of the selected route are associated with the order. To emphasize that:
  1. route assets that have been marked as inactive are not associated;
  2. the downtime route elements are associated with the order.
New assets associated with the route after the orders being generated are not associated with the order.
    • How do I create Work Orders for Routes?
      Through work orders, it is possible to log maintenance work to be carried out on Route assets. The routes can be: Static: the administrator selects the associated assets with or without a filter by function/family/brand/model; Dynamic: the ...
    • How do I create a route?
      Creating routes allows to aggregate a set of assets (equipment or tools) and locations to be applied in maintenance operations. Cegid Valuekeep has two route concepts: Static Routes: the administrator selects the associated assets with or without a ...
    • How to log spare parts in a location?
      In an location, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Locations"; Edit or create a "Location"; On the Spare Parts tab, you can add a Part and the corresponding quantity, you ...
    • How to view the work orders?
      The administrator has a list where it is possible to view all his work orders. To view the list, on the menu select the option Work |  Work Orders. The list has the following criteria:  It is only available for the administrator role. The list is ...
    • How do I log the verification of the tasks associated with the work order?
      When a work order (WO) is in a state that allows work registration, it is possible to perform task verification. Verify Tasks To verify the tasks, follow these steps: Go to Work | Work Orders; Select the WO where you want to verify the task; In the ...
