How do I insert a replacement meter?
To insert a replacement
meter, follow these steps:
- Go to Assets |
Measurements | Meters;
- Select a meter;
- Click on the Operations button to access the meter readings list;
- Click on Create and then on Replace Meter;
- Fill in the
replacement meter reading value. The new reading can be zero if the meter
has been replaced by a new meter or, if it is a used meter, its current
value (lower or higher than the current reading of the old meter, equal to
or greater than zero).
The value of the meter
that corresponds to a meter replacement:
- keeps the current cumulative
reading of the meter;
- maintains the
meter's current average;
- ensures the
increment is zero. Replacing a meter does not mean taking a new
reading, it just means resetting the current value;
- ensures the unit
cost and the total cost is zero;
The replacement date
must be greater than the last reading.
How do I insert meters values?
The meters can be loaded through individual records, in batch or by importing .csv files. Meter values can be introduced in two ways: Value Increase: Difference between the current reading and the previous reading. It is used in Increment-type meters ...
Criteria for Preventive Maintenance with meters
When you create a preventive maintenance with meters and the configured meter in the maintenance plan has meter readings, when you approve the preventive maintenance and generate the events the commutative meter reading in the event starts at the ...
How do I create meters?
The meters are system entities which allow for monitoring parameters of the assets operation in order to trigger Preventive Maintenance actions. The meters can operate as autonomous units or have other meters associated with it. To create a new ...
How do I insert monitoring values?
The Valuekeep monitorings can be fed information from individual records or through batch records by importing .csv files. To insert a new monitoring reading select the option Assets | Meters and Monitorings | Monitorings: A monitoring list is ...
How do I load batch meter readings?
The meter values can be fed information from individual records or through batch records by importing .csv files. To load batch meter reading, select the option Definitions | General | File Importation or using the meter reading list (Assets | Meters ...
