How do I create Work Orders for Routes?
Through work orders, it
is possible to log maintenance work to be carried out on Route
assets.
The routes can be:
- Static: the
administrator selects the associated assets with or without
a filter by function/family/brand/model;
- Dynamic: the
administrator does not select assets but defines the
function/family/brand/model. He can also define whether to include the
elements of sub-entities (roles/families).
To create a Work Order,
follow these steps:
- Go to Work |
Work Orders;
- Click on Create;
- Indicate the WO Description;
- In the Active section, in the Type field, select the Route option;
- In the Route field, add the desired Route. If it doesn't exist, you can create
it;
- Fill in the
remaining fields;
- Click on Save and New.
After generating the
Work Order (WO), the assets of the selected route are associated with the
WO. To emphasize that:
- route assets that
have been marked as inactive are not associated;
- the downtime route elements are associated with the WO.
If the WO is generated
through the order, the route assets are associated with the order. New
assets associated with the route after the WO being generated are not
How to create a work order?
How do I log orders for Routes?
Through the orders, employees of an organization can address intervention requests on route assets for maintenance. The route can be: Static: the administrator selects the associated assets with or without a filter by function/family/brand/model; ...
How to create a work order type?
Work order types allow you to classify the work orders and apply specific behaviors through configuration. To create a work order type, follow these steps: Go to Settings | Work | Work Order Types; The list of work order types will be displayed; ...
How to create a related work order?
Frequently, a maintenance technician is performing a work order and detects another problem, so he needs to solve it and log the work done. To log the work done, there are 3 options: Creating a new work order Adding additional tasks to the work order ...
How do I create the work order type?
Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
