How do I create warehouses with restrictions?
In some maintenance
sectors, technicians have work vans and these contain material to be used in
the work orders. In these cases, it is useful to create a warehouse for each
van so that only the available material in the van can be consumed in the work
orders.
In order for only the
warehouse of the technician's van to be available in material requisitions or
work order consumption, it is necessary to create the warehouse and associate
access restrictions to it.
Create Access Restrictions
- Go to Settings
| System | Groups;
- Click on Create;
- Insert the group's
identification data;
- Select the users
you want to have access to that group;
- Click on Save and New.
Create a Warehouse with Access Restrictions
- Go to Parts and
Inventory | Warehouses:
- Click on Create;
- Insert the
warehouse identification data;
Note: The configurations related to the Externally Managed field are made when the warehouse is created. Once created, you cannot
change it; - Click on the +
icon and then on Access Restrictions;
- In the table, add
the desired group;
How to create warehouses?
To create a warehouse, follow these steps: Go to Parts and Inventory | Warehouses; Click on Create; Insert a code and a description for the warehouse; Activate the Externally managed option if applicable. This configuration can only be set when the ...
How can I create a workshop?
The workshops represent a way of organizing work groups by area, in order to be able to create access restrictions in the operations for allocation of costs to the work orders. To create a new workshop, select the option Workshop & Employees | ...
How to view the current stock for the warehouse parts?
The Parts / Warehouse list allows the maintenance manager to view the existent parts stock in each warehouse. To view the list, select the option "Parts and Inventory | Explore | Parts Stock" or search "Parts Stock". The Parts Stock list has the ...
How to create email templates?
Notifications must have one or more email templates associated with them. To create a new email template, follow these steps: Go to Settings | System | Email Templates; The list of email templates will appear; Click on Create. In the body of the ...
How do I consult the parts/warehouses list?
Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
