How do I consult the parts/warehouses list?
Through the
parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension.
To look the list up,
simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When opening the list from Parts, the
filters are not transferred from one list to another.
The Below Min. Stock field is displayed if the stock is lower than the part's minimum stock.
This feature is only
available for the Administrator profile.
How to view the current stock for the warehouse parts?
The Parts / Warehouse list allows the maintenance manager to view the existent parts stock in each warehouse. To view the list, select the option "Parts and Inventory | Explore | Parts Stock" or search "Parts Stock". The Parts Stock list has the ...
How to create warehouses?
To create a warehouse, follow these steps: Go to Parts and Inventory | Warehouses; Click on Create; Insert a code and a description for the warehouse; Activate the Externally managed option if applicable. This configuration can only be set when the ...
How to record a stock parts entry?
The stock parts entry is always associated to a warehouse, it is not possible in a single stock entry to place several warehouses. To enter a part stock, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish ...
How to report/delete a stock parts issue?
The stock parts issue is always associated to a warehouse, it is not possible in a single part issue to place several warehouses. To issue a part, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish to ...
How to consume spare parts on the work order?
On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
