How do I consult the Labor List?
Through the Labor list,
the maintenance manager can verify all the associated labor logs.
To consult the Labor
list, simply go to Work | Explore Costs | Labor or search for Labor.
This list is only
available for the Administrator and Work Manager profiles, with
the following criteria:
- By default, only
the labor logs for the current quarter are shown;
- The list is sorted
in descending order of the work order's estimated date;
- From the list, you
can access the WO display screen;
- It is possible to search
within the list itself by selecting the appropriate filters.
Labor logs can be made
through the WOs.
How to view preventive labor?
The preventive labor list allows you to have an overview of the employees and their specialties of the preventive plans tasks, as well as the corresponding planned and reported times. To consult the list in the menu, select the Work | Explore Work | ...
How can I see the Labor dashboard?
This dashboard shows metrics and indicators related to labor. To access this dashboard, click on the icon Applications in the top left-hand corner of the header, then Analytics. It will open a tab with all the dashboards provided by Cegid Valuekeep. ...
How to view the labor list?
The Labor list allows the maintenance manager to analyze the records associated with a work order. You can access this list under Work | Explore Costs | Labor or by searching for Labor in the search available in the header. This list is organized ...
How to consult the Request Management list?
The Administrator and the Work Manager have access to a list of requests. To access the list, select the menu option Work | Request Management. List criteria: Availability for the Administrator and Work Manager; The list is sorted in descending order ...
How do I consult the parts/warehouses list?
Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
