How do I consult the follow-up messages associated with a work order?
Work orders (WO) can
contain follow-up messages. This information is very useful for the
administrator to track each WO.
To consult the list,
simply go to Work | Explore Work | Follow-up Messages or search for Follow-up
Messages in the search available in the header.
By default, the list:
- only displays
messages created in the current quarter;
- only displays the
last five messages of each Work Order;
- is sorted in descending
order of the date of the message;
- provides general
filters and column filters.
The number of messages
to display cannot be less than 1.
This option is only
available for the Administrator profile.
How to create a work order?
How to view the traceability of a work order?
A work order can be originated from: I.Another work order; II.An order; III.A preventive maintenance event. To consult the traceability of a work order, select the option "Work | Work Orders". The list of work orders will be displayed; Select the ...
How to report monitoring values associated with the work order?
Every time the Work Order state is configured to allow recording work, it will be possible to associate monitoring readings to the work order, if the work order asset has associated monitoring. To record monitoring readings for the Work Order select ...
How to report meter values associated with the work order?
Every time the Work Order state is configured to allow to record work, it will be possible to associate meter reading to the work order, if the work order asset has associated meters. To record meter readings for the Work Order select the option Work ...
