How do I add locations, equipment, or tools to contracts?
To add locations, equipment, or tools to contracts, follow these steps:
  1. Go to Contracts | Contracts;
  2. Create a contract or select an existing one;
  3. In the Locations section, select the desired locations up to a maximum of 100. You can search by location;
  4. In the Equipment or Tools section, select the equipment or tools you desire up to a maximum of 100. You can search by equipment or tool;
  5. Click on Save.
    • How to add more companies to a subscription?
      On the Universe line, you can have a subscription with several companies and define a set of information for each company, including users and time zone. Add more companies to a subscription Access Settings | General | Companies; Press the Create ...
    • How to create contracts?
      To create a new contract, select the option "Contracts | Contracts": The contract list is presented: Press the "Create" button. When editing the contract, you must consider: The state change must be performed on the detail view interface. If the ...
    • How do I inactivate locations?
      This operation makes it easier to inactivate or dispose of a location and its children. To access this option you must select the option Inactivation History on the location screen. You will be redirected to the screen with the inactivation history ...
    • How to load batch locations?
      The locations can be inserted from individual records or through batch records by importing .csv files. To load batch locations, select the option Settings| General | File Import: The import screen is displayed; Download the template file to be ...
    • How to add equipment?
      The creation of Assets is a critical step in the configuration of the system. The assets you create will be the goods that are subject to maintenance. ​ To create new equipment, select the option Assets | Equipment:  Presents the equipment list On ...
