How can I see the list of Total Costs?
The maintenance manager can check all the cost records associated with a work order.
You can access this list of costs at Work | Explore Costs | Total Costs or by searching for Total Costs inthe search bar in the header.
The list of total costs has the following criteria:
- By omission, only the total costs of the current quarter are displayed.
- The list is sorted in descending order of the scheduled date of the work order.
- From the list, you can access the work order visualisation screen.
- You can search within the list. By default, the filter selected is Work Order, but you can change it.
This feature is available for profiles Administrator and Work Manager.
Total cost records can be made via work orders.
How can I see the Costs dashboard?
The dashboard Costs shows metrics and indicators related to the recording of costs in work orders. To access this dashboard, click on the icon Applications in the top left corner of the header, and then on the option Analytics. A tab will open with ...
How do I consult the Miscellaneous Costs list?
The maintenance manager can check all the miscellaneous cost records associated with a work order. You can access this list under Work | Explore Costs | Miscellaneous Costs or by searching for Miscellaneous Costs in the search available in the ...
How to view the list of total costs?
It is possible to check all costs associated to a work order. The total costs list allows the maintenance manager to check all costs associated to a work order. The list includes the costs in the company configuration currenct and the costs in the ...
How do I create misc costs types?
The misc costs types allow to classify the work order misc costs. To create a new Misc Costs Type select the option Definitions | Work | Misc Costs Types: The list of misc costs types is presented; Press the button "create" The misc costs types have ...
How can I see the Consumables list?
The maintenance manager can check all the Consumables records associated with a work order. You can access this list at Work | Explore Costs | Consumables or search for Consumables in the search bar in the header. The consumables list has the ...
