How can I see my work orders?
The Technician has a list, where you can see all of his assigned Work Orders
To see the list on the menu select the option "Work| My WOs".
The list follows these criteria:
- It is only available for the administrator role.
- The presented list is in decreasing order of work order date.
- From the list it is possible to access the work order view screen.
- It is possible to search the list using the search box and by selecting the field to be searched on the 3 dots.
How can I see the Work Orders dashboard?
Through this dashboard, you have access to metrics and indicators related to Work orders. To access this dashboard, click on the icon Applications in the top left-hand corner of the header and then on the option Analytics. Route work orders are not ...
How do I create the work order type?
Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
How to report consumptions associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
How to report misc costs associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record misc costs. To record misc costs you must access the work order file you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost. ...
