How can I download and install the Valuekeep Integrator?
At the end of this page you can find the latest update of Valuekeep Integrator, suitable for the version 3.
After downloading the attachment, you must follow the steps to install the Valuekeep Integrator:
- Extract the files from the zipped folder to the desired location;
- Follow the path Setup > Completo > IND > Único;
- Double-click the Valuekeep Integrator installation file;
- Select the installation language;
- Follow the installation procedure and acept the terms and conditions.
Last updated on the 08/01/2024.
What is Valuekeep Integrator?
Valuekeep Integrator recommends a conceptual model of data integration and consequent functional logic between systems. As a solution for integration between systems, Valuekeep Integrator brings together a set of characteristics which are considered ...
How to set up the Valuekeep Integrator?
The Valuekeep Integrator can be installed using the following options: · Portal (link): download the Valuekeep Integrator addon setup available and install it; · PRIMAVERA Deployment Center: this option is only available for customers that subscribed ...
What is the Valuekeep-Integrator architecture?
The VALUEKEEP V3 - Valuekeep Integrator plugin, provides in its installation folder: <Install Path> <VKKPlugin\SAMPLES\CONFIGS, an integration solution (VK3_V10_Integration.config), that can be reused as a base example, which can be customized ...
How to subscribe to Valuekeep Integrator?
The use of the Valuekeep Integrator platform requires a subscription to the addon with the same name. The subscription request should be requested to your partner developer.
How does the Valuekeep Integrator work?
Valuekeep Integrator is a generic and abstract platform to implement any data or system integration scenario (across different technologies). The abstraction is represented by the concept of pipeline and consists of the decomposition of a complex ...
