How can I see the list of down times?
On this list, it is possible to view information on the total down time for assets (equipment or tool) and locations. By adding the work order and request columns it is possible to view the down time reports that originated on the request or on the work order..
To view the Down Time History select the option "Assets | Explore | Down Time".
The down time list follows these criteria:
- It is only available for the administrator role.
- By default, only the down time records in which the start and end date are on the current quarter are presented.
How do I use the Assets Explorer?
The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
How do I create assets?
The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
How do I inactivate assets?
This operation makes it easier to inactivate a set of assets and corresponding child assets. To access this option on the equipment or tool view screen, select the option Deactivation History. There are 3 asset inactivation modes: Dispose (this ...
How to see the list of inactivations?
The inactivations list allows the administrator to view the inactivations history. To view the list, select the option "Assets | Explore | Inactivations". The inactivations list follows these criteria: It is only available for the administrator ...
How can I see the list of location changes?
The location changes list allows the administrator to view the asset location changes. To view the list, select the option "Assets | Explore | Location Changes". The location changes list follows these criteria: It is only available for the ...
