How to see the list of inactivations?
The inactivations list allows the administrator to view the inactivations history.
To view the list, select the option "Assets | Explore | Inactivations".
The inactivations list follows these criteria:
  1. It is only available for the administrator role.
  2. By default, only the inactivations whose start date is on the current quarter are presented.
  3. From the list it is possible to access the asset view screen.
    • How do I use the Assets Explorer?
      The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
    • How can I see the list of monitoring values?
      The list of monitoring values allows the maintenance manager to view globally all the values for all monitorings, whether they are from work orders or not. To view the menu list, select the option Assets | Explore | Monitoring Values or search ...
    • How do I create assets?
      The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
    • How do I inactivate assets?
      This operation makes it easier to inactivate a set of assets and corresponding child assets. To access this option on the equipment or tool view screen, select the option Deactivation History. There are 3 asset inactivation modes: Dispose (this ...
    • How can I see the list of location changes?
      The location changes list allows the administrator to view the asset location changes. To view the list, select the option "Assets | Explore | Location Changes". The location changes list follows these criteria:  It is only available for the ...
