How to view the list of total costs?
It is possible to check all costs associated to a work order. The total costs list allows the maintenance manager to check all costs associated to a work order.
The list includes the costs in the company configuration currenct and the costs in the alternative currency (reporting).
To view a total costs list on the menu, select the option "Work | Explore Costs | Total Costs" or search "Total Costs".
The total costs list has the following criteria:
  1. It is only available for the administrator role.
  2. By default, only the total costs of the current quarter.
  3. The list is ordered in decreasing order of work order expected date.
  4. From the list it is possible to access the work order view screen.
  5. It is possible to search the list using the search box and by selecting the field to be searched on the 3 dots.
Costs can be recorded using work orders.
    • How can I see the list of Total Costs?
      The maintenance manager can check all the cost records associated with a work order. You can access this list of costs at Work | Explore Costs | Total Costs or by searching for Total Costs inthe search bar in the header. The list of total costs has ...
    • How do I consult the Miscellaneous Costs list?
      The maintenance manager can check all the miscellaneous cost records associated with a work order. You can access this list under Work | Explore Costs | Miscellaneous Costs or by searching for Miscellaneous Costs in the search available in the ...
    • How to view the work orders?
      The administrator has a list where it is possible to view all his work orders. To view the list, on the menu select the option Work |  Work Orders. The list has the following criteria:  It is only available for the administrator role. The list is ...
    • How to view the list of misc costs?
      It is possible to check all misc cost records associated to a work order. The misc costs list allows the maintenance manager to check all misc cost records associated to a work order. To view a misc costs list on the menu, select the option "Work | ...
    • How can I see the Costs dashboard?
      The dashboard Costs shows metrics and indicators related to the recording of costs in work orders. To access this dashboard, click on the icon Applications in the top left corner of the header, and then on the option Analytics. A tab will open with ...
