How to see the list of failures?
From the Work Order it is possible to record asset failures. The failure list allows the maintenance manager to see asset failures by work order.
To see the menu list select the option "Work | Explore | Failures".
The failure list follows these criteria:
- It is only available for the administrator role.
- By default, only the failures whose expected date is on the current quarter are presented.
- From the list it is possible to access the work order view screen
How can I see my work orders?
The Technician has a list, where you can see all of his assigned Work Orders To see the list on the menu select the option "Work| My WOs". The list follows these criteria: It is only available for the administrator role. The presented list is in ...
How to create a work order?
How to add maintenance plans to the work order?
To add a maintenance plan to a work order, you must access the work order file and open the tab "Maintenance Plans": The list of additional maintenance plans associated to the work order is presented On the list, press the button "+" to add one or ...
How do I create the work order type?
Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
