Example of a custom pipeline configuration
The Valuekeep pipelines can be customized and configured based
on the business model being implemented.
Next, we show an example as a webinar:
How to set up the pipeline execution (Windows Service)?
The host is the process runtime than instantiates the Valuekeep Integrator engine (PipelineEngine) to manage the pipeline execution (using a scheduling procedure or using a specific on-demand context). The platform provides a Windows Service ...
How to customize the pipeline tags for the request URL?
In Valuekeep, there are "POST" requests, which come from keys, as shown below: The method used to create a follow-up report in a work order is: POST ...
WebApi - Pipeline Hashing Calculation
Valuekeep Integration adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been integrated or if it suffered ...
WebApi - Auditing Pipeline
The Valuekeep Integrator conceptually allows to monitor the execution of all pipelines. This feature allows the implementing agent/integrator to control the execution of integration flows and identify irregular situations that require to eventually ...
Plugin V10 – Solution – Example
In the installation folder: <Install Path>, a file (VK3_V10_Integration.config) is provided, which can be reused as a base example when implementing an integration solution. If you want to reuse the example as a potential integration solution, you ...
