How do I enter stock from a requisition?
From the requisition forms, it is possible to enter stock parts. However, this option is only visible on the requisitions tab after the requisition is approved.
To enter stock from a requisition, follow these steps:
- Access the feature Requisitions;
- Create a request or edit an existing one;
- Click on the button Operations and then, on Create Stock Entry;
- Select the parts you want to check in. You can filter the data by Warehouse;
Note: If you select parts from different warehouses, the system displays an error message indicating that you have to select parts from the same warehouse. - Select the warehouse to add stock to;
- Click on the Create Stock Entry;
- The screen displayed is Create Part Entry with the document type predefined and already filled in with the information (warehouse and parts).
The pieces are always displayed in the base unit.
How to view the requisitions workflow?
You can change the flow of states for requests to ensure that they match the organization's way of working. To create or change the settings for a status, follow these steps: Access Settings | Requisitions | Workflow; Click on Create or select an ...
How do I create requisitions?
Using the requisitions, the employees in an organization can request parts to maintenance. To create a requisition, follow these steps: Go to Requisitions | Requisitions; Click on Create; Fill in the necessary fields. Click on Save and New. ...
How to create requisitions using a work order?
It is possible to create and manage requisitions through a work order. The work order must be in a state that allows creation requisitions. To create a requisition from a work order you must: Access the work order list Select the work order for which ...
How to record a stock parts entry?
The stock parts entry is always associated to a warehouse, it is not possible in a single stock entry to place several warehouses. To enter a part stock, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish ...
How to report/delete a stock parts issue?
The stock parts issue is always associated to a warehouse, it is not possible in a single part issue to place several warehouses. To issue a part, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish to ...
