How do I see the Downtime dashboard?
The dashboard Downtime shows metrics and indicators related to asset downtimes.
To access this dashboard, click on the Applications in the top left-hand corner of the header, and then the Analytics option. A tab will open with all the dashboards provided by Cegid Valuekeep. On this page, click on Faults
Information available
Through this dashboard, you can see a range of information on downtime, divided into 4 tabs.
1. Summary
Here, the KPIs are shown on:
  1. Time needed: multiplies the number of days by the amount of working time;
  2. Availability timeTime needed - Downtime;
  3. Downtime: Sum of downtime;
  4. Avail./Time requiredTime available / time required;
To help interpret the data, you can find in the graph information on uptime and downtime per month.
In addition, three graphs are shown with the 10 locations, devices and tools unavailable.
2. Locations
Graphs are shown with the:
  1. Time required, uptime and downtime;
  2. Downtime by location function;
  3. Uptime per month and year.
3. Device
4. Tools
Filters
In any tab, you can change the filters using the option Edit filters. You should bear in mind that
  1. The filter Company only shows the companies to which you have access;
  2. In the filter selector, only data with dashboard records is visible;
  3. Dashboard data is updated at the end of the day.
    • How do I see the Faults dashboard?
      The dashboard Faults shows metrics and indicators relating to the fault record of devices and tools. To access this dashboard, click on the icon Applications in the top left corner of the header, and then in the option Analytics. A tab will open with ...
    • How can I see the Labor dashboard?
      This dashboard shows metrics and indicators related to labor. To access this dashboard, click on the icon Applications in the top left-hand corner of the header, then Analytics. It will open a tab with all the dashboards provided by Cegid Valuekeep. ...
    • How can I see the Costs dashboard?
      The dashboard Costs shows metrics and indicators related to the recording of costs in work orders. To access this dashboard, click on the icon Applications in the top left corner of the header, and then on the option Analytics. A tab will open with ...
    • How can I see the Requests dashboard?
      Through this dashboard, you have access to metrics and indicators related to Requests. To access this dashboard, click on the icon Applications in the top left corner of the header and then in the option Analytics. A tab will open with all the ...
    • How do I use the Analytics feature (dashboards)?
      Cegid Valuekeep is focused on developing features that help decision-making based on data that are exact and precise. For this purpose, there is an add-on tool which enables companies to monitor performance, reduce downtime and reduce costs. Once you ...
