How do I delete preventive maintenances?
To
delete preventive maintenances, select the option Definitions| General |
File Import:
- The import screen is displayed;
- Select the option Delete Preventive Maintenances;
- Download the template file to be loaded, on the upper part of
the screen and fill in the file;
- Later, you must fill in the file according to the rules:
- The field PreventiveMaintenanceKey must be defined.
- When the import is finished, the import date will be presented
and it might (or not) contain messages with import details. If an import occurs
without errors/warnings, no information on the import details will be
presented. If there are errors/warnings, you can see the errors by clicking on
the number of messages.
When
filling in the file, you must consider the following field:
- The
field PreventiveMaintenanceKey must be in the format: <preventive
maintenance version>.<preventive maintenance key> , for example,
3.0000000007.
- The file must always be
of the CSV type and the separator character must be ; (semicolon).
- You must not
remove or add columns to the downloaded template.
- You must only specify the field 'Company' if you have more
than one company in your subscription.
How to import preventive maintenances?
The Preventive Maintenances can be inserted from individual records or through batch records by importing .xml files. To load batch preventive maintenances, select the option "Settings | General | File Imports" or using the Preventive Maintenances ...
What is preventive maintenances batch management?
Preventive maintenances management was designed to allow you to simultaneously change the state, delete or create new versions for a set of preventive maintenances. For that, you must access Work | Preventive Maintenance | Preventive Maintenance ...
How to import parts?
The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
How to delete maintenance plans?
To delete maintenance plans in batches, select the option Definitions| General | File Import: The import screen is presented; Select the option Delete Maintenance Plans; Download the template file to be loaded, on the upper part of the screen and ...
How can I delete parts?
To delete batch parts, select the option Definitions| General | File Import: The import screen is displayed; Select the option Delete Parts; Download the template file to be loaded, on the upper part of the screen and fill in the file; Later, you ...
